07-Layer 2—WAN Access Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)- R9141-6W10007-Layer 2—WAN Access Command Reference
01-PPP commands
01-PPP commands 544.22 KB
PPP and MP commands· 1
PPP commands· 1
bandwidth· 1
default 1
description· 2
display interface virtual-access· 3
display interface virtual-template· 6
display ip pool 9
display ppp access-user 10
display ppp compression iphc· 15
display ppp packet statistics· 17
interface virtual-template· 22
ip address ppp-negotiate· 23
ip pool 24
ip pool gateway· 25
link-protocol ppp· 26
mtu· 26
nas-port-type· 27
ppp accm·· 28
ppp access-user log enable· 29
ppp account-statistics enable· 29
ppp acfc local-request 30
ppp acfc remote-reject 31
ppp authentication-mode· 32
ppp chap password· 33
ppp chap user 34
ppp compression iphc enable· 35
ppp compression iphc rtp-connections· 36
ppp compression iphc tcp-connections· 37
ppp ipcp dns· 38
ppp ipcp dns admit-any· 38
ppp ipcp dns request 39
ppp ipcp remote-address match· 40
ppp ip-pool route· 40
ppp lcp delay· 41
ppp lqm·· 42
ppp lqm lcp-echo· 43
ppp pap local-user 44
ppp pfc local-request 45
ppp pfc remote-reject 45
ppp timer negotiate· 46
remote address· 46
remote address dhcp client-identifier 48
reset counters interface virtual-access· 49
reset ppp access-user 49
reset ppp compression iphc· 50
reset ppp packet statistics· 51
timer-hold· 51
timer-hold retry· 52
MP commands· 53
display interface mp-group· 53
display ppp mp· 56
interface mp-group· 57
ppp mp· 58
ppp mp binding-mode· 58
ppp mp endpoint 59
ppp mp fast-forward enable· 60
ppp mp fragment disable· 61
ppp mp lfi delay-per-frag· 62
ppp mp lfi enable· 62
ppp mp lfi size-per-frag· 63
ppp mp load-sharing mode strict-round-robin· 64
ppp mp max-bind· 64
ppp mp min-bind· 65
ppp mp min-fragment 66
ppp mp mp-group· 67
ppp mp short-sequence· 67
ppp mp sort-buffer-size· 68
ppp mp timer lost-fragment 69
ppp mp user 70
ppp mp virtual-template· 71
reset counters interface mp-group· 71
shutdown· 72
PPP and MP commands
PPP commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
VT interface view
MP-group interface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of Virtual-Template 10 to 1000 kbps.
[Sysname] interface virtual-template 10
[Sysname-Virtual-Template10] bandwidth 1000
# Set the expected bandwidth of MP-group 1/2/1 to 1000 kbps.
[Sysname] interface mp-group 1/2/1
[Sysname-MP-group1/2/1] bandwidth 1000
default
Use default to restore the default settings for a VT or MP-group interface.
default
VT interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command before using it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use the undo forms of these commands or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of Virtual-Template 10.
[Sysname-Virtual-Template10] default
# Restore the default settings of MP-group 1/2/1.
[Sysname-MP-group1/2/1] default
description
Use description to set the description for a VT or MP-group interface.
The description for a VT or MP-group interface is interface name Interface (for example, Virtual-Template1 Interface or MP-group1/2/1 Interface).
VT interface view
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description for Virtual-Template 10 to virtual-interface.
[Sysname-Virtual-Template10] description virtual-interface
# Set the description for MP-group 1/2/1 to mpgroup-interface.
[Sysname-MP-group1/2/1] description mpgroup-interface
Use display interface virtual-access to display information about VA interfaces.
display interface [ virtual-access [ interface-number ] ] [ brief [ description | down ] ]
virtual-access [ interface-number ]: Specifies an existing VA interface by its number. If you do not specify the virtual-access keyword, the command displays information about all interfaces except VA interfaces on the device. If you specify the virtual-access keyword without the interface-number argument, the command displays information about all VA interfaces.
description: Displays interface description information. This keyword does not apply to VA interfaces because VA interfaces do not support description configuration.
down: Displays information about interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about all interfaces.
# Display information about Virtual-Access 1.
<Sysname> display interface virtual-access 1
Virtual-Access1
Current state: UP
Line protocol state: UP
Description: Virtual-Access1 Interface
Bandwidth: 1920kbps
Hold timer: 10 seconds, retry times: 5
Internet address: 122.1.1.1/24 (primary)
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 1920000 bps
Main interface: Virtual-Template1
Last link flapping: Never
Input: 2 packets, 24 bytes, 0 drops
Output: 2 packets, 24 bytes, 0 drops
# Display brief information about Virtual-Access 1.
<Sysname> display interface virtual-access 1 brief
Protocol: (s) - spoofing
VA1                  DOWN DOWN     --
# Display brief information about VA interfaces in physically down state and the causes.
<Sysname> display interface virtual-access brief down
VA1                  DOWN Not connected
Current state
Physical and administrative states of the interface:
·     DOWN—The interface is administratively up but physically down.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state: UP or DOWN.
Interface description.
Bandwidth
Expected bandwidth of the interface.
Hold timer
Interval at which the interface sends keepalive packets.
retry times
Keepalive retry limit.
The interface determines that its peer has been down if it does not receive a keepalive response when the keepalive retry limit is reached.
The interface cannot process IP packets currently.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
The PPP connection has been successfully established.
Physical
Physical type of the interface.
Main interface
VT interface associated with the VA interface.
Traffic statistics of the interface output queues.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Last time when statistics on the interface were cleared. Never indicates that statistics on the interface were never cleared.
Average rate of input packets and output packets in the last 300 seconds.
Total number of inbound packets of the interface (in the number of packets and in bytes), and the number of packets dropped among the inbound packets.
Total number of outbound packets of the interface (in the number of packets and in bytes), and the number of packets dropped among the outbound packets.
Brief information about Layer 3 interfaces.
Link status:
·     ADM—The interface has been administratively shut down. To recover its physical state, execute the undo shutdown command.
·     Stby—The interface is a backup interface. To see the primary interface, use the display interface-backup state command in High Availability Command Reference.
Indicates the line protocol is UP, but the physical link is an on-demand link or is not present.
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWNThe interface is physically down.
Protocol
·     UP—The line protocol is up.
·     DOWN—The line protocol is down.
·     UP(s)—The line protocol is up, but the physical link is an on-demand link or is not present.
Primary IP
Primary IP address of the interface.
Interface description configured by using the description command. This field does not apply to VA interfaces because VA interfaces do not support description configuration.
Cause
Cause for the physical state of the interface to be Down.
Not connected indicates no physical link exists (possibly because the network cable is disconnected or faulty).
Use display interface virtual-template to display information about VT interfaces.
display interface [ virtual-template [ interface-number ] ] [ brief [ description | down ] ]
virtual-template [ interface-number ]: Specifies an existing VT interface by its number. If you do not specify the virtual-template keyword, the command displays information about all interfaces except VA interfaces on the device. If you specify the virtual-template keyword without the interface-number argument, the command displays information about all existing VT interfaces.
description: Displays complete interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description if the description contains more than 27 characters.
# Display detailed information about Virtual-Template 1.
<Sysname> display interface virtual-template 1
Virtual-Template1
Current state: DOWN
Line protocol state: DOWN
Description: Virtual-Template1 Interface
Bandwidth: 100000kbps
Internet address: 192.168.1.200/24 (primary)
LCP: initial
Physical: None, baudrate: 100000000 bps
# Display brief information about Virtual-Template 1.
<Sysname> display interface virtual-template 1 brief
VT1                  DOWN DOWN     --
# Display brief information about the VT interfaces in physically down state and the causes.
<Sysname> display interface Virtual-Template brief down
VT0                  DOWN Not connected
VT12                 DOWN Not connected
VT1023               DOWN Not connected
Current state
Physical state of the interface. This field for a VT interface can only be DOWN.
Line protocol state
Data link layer state. This field for a VT interface can only be DOWN.
Bandwidth
Hold timer
retry times
LCP initial
LCP initialization is complete.
Physical
Output queue - Urgent queuing: Size/Length/Discards 0/100/0)
Output queue - Protocol queuing: Size/Length/Discards 0/500/0)
Output queue - FIFO queuing: Size/Length/Discards 0/75/0)
Link status:
·     ADM—The interface has been administratively shut down. To recover its physical state, use the undo shutdown command.
·     Stby—The interface is operating as a backup interface. To see the primary interface, use the display interface-backup state command in High Availability Command Reference.
Link
Physical link state of the interface. This field for a VT interface can only be DOWN.
Protocol
Line protocol state of the interface. This field for a VT interface can only be DOWN.
Primary IP
Interface description configured by using the description command. If you do not specify the description keyword, the display interface brief command displays a maximum of 27 characters of the description. If you specify the description keyword, the command displays the complete description.
Cause
Causes for the physical state of the interface to be Down.
display ip pool
Use display ip pool to display PPP address pools.
display ip pool [ pool-name | group group-name ]
pool-name: Specifies a PPP address pool by its name, a case-sensitive string of 1 to 63 characters.
group group-name: Displays PPP address pools in a group specified by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify any parameters, the command displays brief information about all PPP address pools.
If you specify an address pool, the command displays detailed information about the specified PPP address pool.
# Display brief information about all PPP address pools.
<Sysname> display ip pool
Group name: a
  Pool name           Start IP address    End IP address      Free   In use
  aaa1                1.1.1.1             1.1.1.5             5      0
  aaa2                1.1.1.6             1.1.1.10            5      0
Group name: b
  bbb                 1.1.2.1             1.1.2.5             4      1
                      2.2.2.1             2.2.2.5             5      0
# Display brief information about the PPP address pools in group a.
<Sysname> display ip pool group a
Group name: a
# Display detailed information about PPP address pool bbb.
<Sysname> display ip pool bbb
Group name: b
                      2.2.2.1             2.2.2.5             5      0
In use IP addresses:
  IP address      Interface
  1.1.2.1         POS2/2/0
Group name: b
                      2.2.2.1             2.2.2.5             5      0
  1.1.2.1         Virtual-Template1
Free
Number of free IP addresses.
In use
Number of IP addresses that have been assigned.
In use IP addresses
Information about the IP addresses that have been assigned.
Local interface that requests the IP address for the peer interface.
ip pool
Use display ppp access-user to display PPP user information.
display ppp access-user { domain domain-name | interface interface-type interface-number [ count ] | ip-address ipv4-address  | ipv6-address ipv6-address| username user-name | user-type { lac | lns | pppoe } [ count ] }
domain domain-name: Displays information about PPP access users coming online through an ISP domain specified by its name, a case-sensitive string of 1 to 255 characters.
interface interface-type interface-number: Displays brief information about PPP users on the specified interface.
ip-address ipv4-address: Displays detailed information about the PPP user specified by its IPv4 address.
ipv6-address ipv6-address: Displays detailed information about the PPP user specified by its IPv6 address.
username user-name: Displays detailed information about the PPP user specified by its username, a case-sensitive string of 1 to 80 characters.
user-type: Displays brief information about online users of the specified type.
lac: Displays brief information about L2TP users for an LAC.
lns: Displays brief information about L2TP users for an LNS.
pppoe: Displays brief information about PPPoE users.
count: Displays the total number of PPP users matching the specified criterion.
Brief information about a PPP user includes the following:
·     Brief name of the VA interface.
·     Username.
·     MAC address.
·     IPv4 address, IPv6 address, or IPv6 prefix of the PPP user.
Detailed information about a PPP user includes the following:
·     User ID.
·     Username.
·     Authentication information.
·     Uplink and downlink traffic.
·     Access start time of the PPP user.
In an L2TP network, this command is supported on an LAC only if a remote system dials in to the LAC through a PPPoE network. For more information about L2TP, see L2TP configuration in User Access and Authentication Configuration Guide.
# Display brief information about PPP users on Ten-GigabitEthernet 0/0/6.
<Sysname> display ppp access-user interface ten-gigabitethernet 0/0/6
Interface     Username    MAC address     IP address       IPv6 address    IPv6 PDPrefix
VA0           user1@dm1   0001-0101-9101  192.168.100.173  -               -
VA1           user2@dm2   0001-0101-9101  192.168.80.173   2000::1         -
# Display the total number of PPP users on Ten-GigabitEthernet 0/0/6.
<Sysname> display ppp access-user interface ten-gigabitethernet 0/0/6 count
Total users: 2
Name of the VA interface corresponding to the user.
Username
Username of the user.
A hyphen (-) means that the user does not need authentication.
MAC address
MAC address of the user.
A hyphen (-) means that the user is not a PPPoE user.
IP address
IP address of the user. A hyphen (-) means that no IP address is assigned to the user.
IPv6 address
‌IPv6 address of the user. A hyphen (-) means that no IPv6 address is assigned to the user.
IPv6 PD prefix
‌IPv6 prefix of the user. A hyphen (-) means that no IPv6 prefix is assigned to the user.
Total users
Total number of PPP users.
# Display detailed information about the PPP user whose IP address is 50.50.50.3.
<Sysname> display ppp access-user ip-address 50.50.50.3
Basic:
  Interface: VA0
  User ID: 0x28000002
  Username: user1@hrss
  Domain: hrss
  Access interface: RAGG2
  Service-VLAN/Customer-VLAN: -/-
  MAC address: 0000-0000-0001
  IP address: 50.50.50.3
  IPv6 address: -
  IPv6 PD prefix: -
  VPN instance: 123
  Access type: PPPoE
  Authentication type: CHAP
AAA:
  Authentication state: Authenticated
  Authorization state: Authorized
  Realtime accounting switch: Open
  Realtime accounting interval: 60s
  Login time: 2019-1-19  2:42:3:358
  Accounting start time: 2019-1-19  2:42:3:382
  Online time(hh:mm:ss): 0:7:34
  Accounting state: Accounting
  Idle cut: 0 sec  0 byte
  Session timeout: 12000 s
  Time remained: 8000 s
  Byte remained: 20971520 bytes
  Redirect WebURL: http://6.6.6.6
ACL&QoS:
  User profile: profile123 (active)
  User group profile: -
  Inbound CAR: CIR 64000bps PIR 640000bps CBS 500bit
  Outbound CAR: CIR 64000bps PIR 640000bps CBS 500bit
NAT:
  Global IP address: 111.8.0.200
  Port block: 28744-28748
Flow Statistic:
  IPv4 uplink   packets/bytes: 7/546
  IPv4 downlink packets/bytes: 0/0
  IPv6 uplink   packets/bytes: 0/0
  IPv6 downlink packets/bytes: 0/0
ITA:
  Level-1 uplink   packets/bytes: 100/128000
          downlink packets/bytes: 200/256000
  Level-2 uplink   packets/bytes: 100/128000
Table 5 Command output
Basic
Basic information.
Brief name of the VA interface that corresponds to the user.
Username
Domain
ISP domain name for authentication.
A hyphen (-) means that no ISP domain is specified for authentication.
Access interface
Name of the access interface of the user.
Service provider VLAN and customer VLAN information of the user.
A hyphen (-) means that no VLAN information is available.
IP address
IPv6 address
IPv6 PD prefix
‌Delegated IPv6 prefix of the user. A hyphen (-) means that no delegated IPv6 prefix is assigned to the user.
VPN instance
‌VPN instance to which the user belongs.
A hyphen (-) means that the user is not bound to any VPN instance.
Access type
Access type of the user:
·     PPPoE.
·     L2TP.
Authentication type
Authentication type of the user:
·     PAP.
·     CHAP.
·     MS-CHAP.
·     MS-CHAP-V2.
Authentication state of the user:
·     Idle—The user has not been authenticated.
·     Authenticating—The user is being authenticated.
·     Authenticated—The user has been authenticated.
Authorization state
Authorization state of the user:
·     Idle—The user has not been authorized.
·     Authorizing—The user is being authorized.
·     Authorized—The user has been authorized.
·     Open—The switch is on.
·     Closed—The switch is off.
Realtime accounting interval in seconds.
A hyphen (-) means that no real-time accounting interval is authorized.
Login time
Time when the user accessed the device through PPP.
Time when accounting started.
A hyphen (-) means that no accounting is performed on the user.
Online duration of the current login.
Accounting state
Accounting state of the user:
·     AccountingAccounting is on.
·     StopAccounting stops.
Idle cut
Traffic threshold for logging off the user in idle state.
If the traffic is less than the threshold within the specified period, the user is forcibly logged off.
Session timeout
Authorization time for the user, in seconds.
A hyphen (-) means that no authorization time is specified for the user.
Time remained
Remaining time for the user to stay online, in seconds.
Byte remained
Remaining traffic for the user.
A hyphen (-) means that no authorization traffic is specified for the user.
Redirect WebURL
Redirect Web URL address for the user.
A hyphen (-) means that no redirect Web URL address is specified for the user.
User profile
Name of the authorized user profile. The hyphen (-) means that no user profile is authorized.
The user profile has two states:
·     activeThe authorized user profile is successfully issued.
·     inactiveThe authorized user profile fails to be issued.
User group profile
Name of the authorized user group profile. The hyphen (-) means that no user group profile is authorized.
The user group profile has two states:
·     activeThe authorized user group profile is successfully issued.
·     inactiveThe authorized user group profile fails to be issued.
Inbound CAR
Authorized inbound CAR parameters, which contain the CIR (in bps), the PIR (in bps), and the CBS (in bits).
Outbound CAR
Authorized outbound CAR parameters, which contain the CIR (in bps), the PIR (in bps), and the CBS (in bits).
Global IP address
Global IP address of the user. This field is displayed if NAT444 is used. For information about NAT444, see NAT Configuration Guide.
Port block
Port block of the user, from the start port to the end port.
Number of packets and bytes for IPv4 uplink traffic.
Number of packets and bytes for IPv4 downlink traffic.
‌Number of packets and bytes for IPv6 uplink traffic.
‌Number of packets and bytes for IPv6 downlink traffic.
ITA
ITA statistics.
ITA statistics are displayed after ITA is enabled.
If the traffic-separate enable command is executed, ITA statistics are not included in flow statistics. For information about ITA and the traffic-separate enable command, see AAA configuration in User Access and Authentication Configuration Guide.
Level-n uplink   packets/bytes
Number of packets and bytes for uplink traffic at accounting level n. The value for n depends on the traffic level command, and its value range is 1 to 8.
Use display ppp compression iphc to display IP header compression (IPHC) statistics.
display ppp compression iphc { rtp | tcp } [ interface interface-type interface-number ]
rtp: Displays IPHC RTP header compression statistics.
tcp: Displays IPHC TCP header compression statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays IPHC statistics on all interfaces.
When IPHC applies to an MP link, the following rules apply:
·     If an MP template is used, such as a VT interface or a dialer interface, the associated VA interface performs IPHC. You can view the compression information on the VA interface.
·     If an MP-group interface is used, the MP-group interface performs IPHC. You can view the compression information on the MP-group interface.
When IPHC applies to a normal PPP link, the physical interface performs IPHC. You can view the compression information on the physical interface.
# Display IPHC RTP header compression statistics.
<Sysname> display ppp compression iphc rtp
----------------------Slot1----------------------
Interface: Virtual-Access0
  Received:
    Compressed/Error/Total: 0/0/0 packets
  Sent:
    Compressed/Total: 0/0 packets
    Sent/Saved/Total: 0/0/0 bytes
    Packet-based compression ratio: 0%
    Byte-based compression ratio: 0%
  Connections:
    Rx/Tx: 16/16
    Five-Minute-Miss: 0 (Misses/5Mins)
    Max-Miss: 0
----------------------Slot2----------------------
  Received:
    Compressed/Error/Total: 20/5/40 packets
  Sent:
    Compressed/Total: 34/40 packets
    Sent/Saved/Total: 1131/1210/2341 bytes
    Packet-based compression ratio: 85%
    Byte-based compression ratio: 51%
  Connections:
    Rx/Tx: 16/16
    Max-Miss: 0
# Display IPHC TCP header compression statistics.
<Sysname>display ppp compression iphc tcp
  Received:
  Sent:
  Connections:
    Rx/Tx: 16/16
    Max-Miss: 0
  Received:
  Sent:
  Connections:
    Rx/Tx: 16/16
    Max-Miss: 0
Table 6 Command output
Received:
Statistics for received packets:
·     Compressed—Number of compressed packets.
·     Error—Number of error packets.
·     Total—Total number of received packets.
Sent:
  Compressed/Total
  Sent/Saved/Total
Statistics for sent packets:
·     Total—Total number of sent packets.
·     Sent—Bytes of sent packets.
·     Saved—Bytes of saved packets.
·     Total—Total bytes to be sent if packets are not compressed.
·     Packet-based compression ratio—Ratio of compressed packets to the total sent packets.
·     Byte-based compression ratio—Ratio of saved bytes to the total sent bytes.
Connections:
  Rx/Tx
  Five-Minute-Miss
  Max-Miss
Number of connections.
·     Rx—Number of connections that the receiver can decompress.
·     Tx—Number of connections that the sender can compress.
·     Five-Minute-Miss—Number of search failures within the last 5 minutes.
·     Max-Miss—Maximum number of search failures within 5 minutes.
Use display ppp packet statistics to display PPP negotiation packet statistics.
display ppp packet statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays PPP negotiation packet statistics for all cards.
# Display PPP negotiation packet statistics for the specified slot.
<Sysname> display ppp packet statistics slot 0
PPP packet statistics in slot 0:
-------------------------------LCP------------------------------------
SEND_LCP_CON_REQ      : 0           RECV_LCP_CON_REQ      : 0
SEND_LCP_CON_NAK      : 0           RECV_LCP_CON_NAK      : 0
SEND_LCP_CON_REJ      : 0           RECV_LCP_CON_REJ      : 0
SEND_LCP_CON_ACK      : 0           RECV_LCP_CON_ACK      : 0
SEND_LCP_CODE_REJ     : 0           RECV_LCP_CODE_REJ     : 0
SEND_LCP_PROT_REJ     : 0           RECV_LCP_PROT_REJ     : 0
SEND_LCP_TERM_REQ     : 0           RECV_LCP_TERM_REQ     : 0
SEND_LCP_TERM_ACK     : 0           RECV_LCP_TERM_ACK     : 0
SEND_LCP_ECHO_REQ     : 0           RECV_LCP_ECHO_REQ     : 0
SEND_LCP_ECHO_REP     : 0           RECV_LCP_ECHO_REP     : 0
SEND_LCP_FAIL         : 0
-------------------------------IPCP-----------------------------------
SEND_IPCP_CON_REQ     : 0           RECV_IPCP_CON_REQ     : 0
SEND_IPCP_CON_NAK     : 0           RECV_IPCP_CON_NAK     : 0
SEND_IPCP_CON_REJ     : 0           RECV_IPCP_CON_REJ     : 0
SEND_IPCP_CON_ACK     : 0           RECV_IPCP_CON_ACK     : 0
SEND_IPCP_CODE_REJ    : 0           RECV_IPCP_CODE_REJ    : 0
SEND_IPCP_PROT_REJ    : 0           RECV_IPCP_PROT_REJ    : 0
SEND_IPCP_TERM_REQ    : 0           RECV_IPCP_TERM_REQ    : 0
SEND_IPCP_TERM_ACK    : 0           RECV_IPCP_TERM_ACK    : 0
SEND_IPCP_FAIL        : 0
-------------------------------IPV6CP---------------------------------
SEND_IPV6CP_CON_REQ   : 0           RECV_IPV6CP_CON_REQ   : 0
SEND_IPV6CP_CON_NAK   : 0           RECV_IPV6CP_CON_NAK   : 0
SEND_IPV6CP_CON_REJ   : 0           RECV_IPV6CP_CON_REJ   : 0
SEND_IPV6CP_CON_ACK   : 0           RECV_IPV6CP_CON_ACK   : 0
SEND_IPV6CP_CODE_REJ  : 0           RECV_IPV6CP_CODE_REJ  : 0
SEND_IPV6CP_PROT_REJ  : 0           RECV_IPV6CP_PROT_REJ  : 0
SEND_IPV6CP_TERM_REQ  : 0           RECV_IPV6CP_TERM_REQ  : 0
SEND_IPV6CP_TERM_ACK  : 0           RECV_IPV6CP_TERM_ACK  : 0
SEND_IPV6CP_FAIL      : 0
-------------------------------OSICP---------------------------------
SEND_OSICP_CON_REQ    : 0           RECV_OSICP_CON_REQ    : 0
SEND_OSICP_CON_NAK    : 0           RECV_OSICP_CON_NAK    : 0
SEND_OSICP_CON_REJ    : 0           RECV_OSICP_CON_REJ    : 0
SEND_OSICP_CON_ACK    : 0           RECV_OSICP_CON_ACK    : 0
SEND_OSICP_CODE_REJ   : 0           RECV_OSICP_CODE_REJ   : 0
SEND_OSICP_PROT_REJ   : 0           RECV_OSICP_PROT_REJ   : 0
SEND_OSICP_TERM_REQ   : 0           RECV_OSICP_TERM_REQ   : 0
SEND_OSICP_TERM_ACK   : 0           RECV_OSICP_TERM_ACK   : 0
SEND_OSICP_FAIL       : 0
-------------------------------MPLSCP---------------------------------
SEND_MPLSCP_CON_REQ   : 0           RECV_MPLSCP_CON_REQ   : 0
SEND_MPLSCP_CON_NAK   : 0           RECV_MPLSCP_CON_NAK   : 0
SEND_MPLSCP_CON_REJ   : 0           RECV_MPLSCP_CON_REJ   : 0
SEND_MPLSCP_CON_ACK   : 0           RECV_MPLSCP_CON_ACK   : 0
SEND_MPLSCP_CODE_REJ  : 0           RECV_MPLSCP_CODE_REJ  : 0
SEND_MPLSCP_PROT_REJ  : 0           RECV_MPLSCP_PROT_REJ  : 0
SEND_MPLSCP_TERM_REQ  : 0           RECV_MPLSCP_TERM_REQ  : 0
SEND_MPLSCP_TERM_ACK  : 0           RECV_MPLSCP_TERM_ACK  : 0
SEND_MPLSCP_FAIL      : 0
--------------------------------AUTH ----------------------------------
SEND_PAP_AUTH_REQ        : 0           RECV_PAP_AUTH_REQ        : 0
SEND_PAP_AUTH_ACK        : 0           RECV_PAP_AUTH_ACK        : 0
SEND_PAP_AUTH_NAK        : 0           RECV_PAP_AUTH_NAK        : 0
SEND_CHAP_AUTH_CHALLENGE : 0           RECV_CHAP_AUTH_CHALLENGE : 0
SEND_CHAP_AUTH_RESPONSE  : 0           RECV_CHAP_AUTH_RESPONSE  : 0
SEND_CHAP_AUTH_ACK       : 0           RECV_CHAP_AUTH_ACK       : 0
SEND_CHAP_AUTH_NAK       : 0           RECV_CHAP_AUTH_NAK       : 0
SEND_PAP_AUTH_FAIL       : 0           SEND_CHAP_AUTH_FAIL      : 0
Table 7 Command output
LCP
LCP packet statistics.
·     SEND_LCP_CON_REQ—Number of sent link configuration request packets.
·     RECV_LCP_CON_REQ—Number of received link configuration request packets.
·     SEND_LCP_CON_NAK—Number of sent link configuration NAK packets.
·     RECV_LCP_CON_NAK—Number of received link configuration NAK packets.
·     SEND_LCP_CON_REJ—Number of sent link configuration reject packets.
·     RECV_LCP_CON_REJ—Number of received link configuration reject packets.
·     SEND_LCP_CON_ACK—Number of sent link configuration ACK packets.
·     RECV_LCP_CON_ACK—Number of received link configuration ACK packets.
·     SEND_LCP_CODE_REJ—Number of sent link configuration code reject packets.
·     RECV_LCP_CODE_REJ—Number of received link configuration code reject packets.
·     SEND_LCP_PROT_REJ—Number of sent link configuration protocol reject packets.
·     RECV_LCP_PROT_REJ—Number of received link configuration protocol reject packets.
·     SEND_LCP_TERM_REQ—Number of sent link termination request packets.
·     RECV_LCP_TERM_REQ—Number of received link termination request packets.
·     SEND_LCP_TERM_ACK—Number of sent link termination ACK packets.
·     RECV_LCP_TERM_ACK—Number of received link termination ACK packets.
·     SEND_LCP_ECHO_REQ—Number of sent LCP echo request packets.
·     RECV_LCP_ECHO_REQ—Number of received LCP echo request packets.
·     SEND_LCP_ECHO_REP—Number of sent LCP echo reply packets.
·     RECV_LCP_ECHO_REP—Number of received LCP echo reply packets.
·     SEND_LCP_FAIL—Number of sent link failure packets.
IPCP
IPCP packet statistics.
·     SEND_IPCP_CON_REQ—Number of sent IP address negotiation request packets.
·     RECV_IPCP_CON_REQ—Number of received IP address negotiation request packets.
·     SEND_IPCP_CON_NAK—Number of sent IP address negotiation NAK packets.
·     RECV_IPCP_CON_NAK—Number of received IP address negotiation NAK packets.
·     SEND_IPCP_CON_REJ—Number of sent IP address negotiation reject packets.
·     RECV_IPCP_CON_REJ—Number of received IP address negotiation reject packets.
·     SEND_IPCP_CON_ACK—Number of sent IP address negotiation ACK packets.
·     RECV_IPCP_CON_ACK—Number of received IP address negotiation ACK packets.
·     SEND_IPCP_CODE_REJ—Number of sent IP address negotiation code reject packets.
·     RECV_IPCP_CODE_REJ—Number of received IP address negotiation code reject packets.
·     SEND_IPCP_PROT_REJ—Number of sent IP address negotiation protocol reject packets.
·     RECV_IPCP_PROT_REJ—Number of received IP address negotiation protocol reject packets.
·     SEND_IPCP_TERM_REQ—Number of sent IP address negotiation termination request packets.
·     RECV_IPCP_TERM_REQ—Number of received IP address negotiation termination request packets.
·     SEND_IPCP_TERM_ACK—Number of sent IP address negotiation termination ACK packets.
·     RECV_IPCP_TERM_ACK—Number of received IP address negotiation termination ACK packets.
·     SEND_IPCP_FAIL—Number of sent IP address negotiation failure packets.
IPV6CP
‌IPv6CP packet statistics.
·     SEND_IPV6CP_CON_REQ—Number of sent IPv6 address negotiation request packets.
·     RECV_IPV6CP_CON_REQ—Number of received IPv6 address negotiation request packets.
·     SEND_IPV6CP_CON_NAK—Number of sent IPv6 address negotiation NAK packets.
·     RECV_IPV6CP_CON_NAK—Number of received IPv6 address negotiation NAK packets.
·     SEND_IPV6CP_CON_REJ—Number of sent IPv6 address negotiation reject packets.
·     RECV_IPV6CP_CON_REJ—Number of received IPv6 address negotiation reject packets.
·     SEND_IPV6CP_CON_ACK—Number of sent IPv6 address negotiation ACK packets.
·     RECV_IPV6CP_CON_ACK—Number of received IPv6 address negotiation ACK packets.
·     SEND_IPV6CP_CODE_REJ—Number of sent IPv6 address negotiation code reject packets.
·     RECV_IPV6CP_CODE_REJ—Number of received IPv6 address negotiation code reject packets.
·     SEND_IPV6CP_PROT_REJ—Number of sent IPv6 address negotiation protocol reject packets.
·     RECV_IPV6CP_PROT_REJ—Number of received IPv6 address negotiation protocol reject packets.
·     SEND_IPV6CP_TERM_REQ—Number of sent IPv6 address negotiation termination request packets.
·     RECV_IPV6CP_TERM_REQ—Number of received IPv6 address negotiation termination request packets.
·     SEND_IPV6CP_TERM_ACK—Number of sent IPv6 address negotiation termination ACK packets.
·     RECV_IPV6CP_TERM_ACK—Number of received IPv6 address negotiation termination ACK packets.
·     SEND_IPV6CP_FAIL—Number of sent IPv6 address negotiation failure packets.
OSICP
OSICP packet statistics.
·     SEND_OSICP_CON_REQ—Number of sent OSI address negotiation request packets.
·     RECV_OSICP_CON_REQ—Number of received OSI address negotiation request packets.
·     SEND_OSICP_CON_NAK—Number of sent OSI address negotiation NAK packets.
·     RECV_OSICP_CON_NAK—Number of received OSI address negotiation NAK packets.
·     SEND_OSICP_CON_REJ—Number of sent OSI address negotiation reject packets.
·     RECV_OSICP_CON_REJ—Number of received OSI address negotiation reject packets.
·     SEND_OSICP_CON_ACK—Number of sent OSI address negotiation ACK packets.
·     RECV_OSICP_CON_ACK—Number of received OSI address negotiation ACK packets.
·     SEND_OSICP_CODE_REJ—Number of sent OSI address negotiation code reject packets.
·     RECV_OSICP_CODE_REJ—Number of received OSI address negotiation code reject packets.
·     SEND_OSICP_PROT_REJ—Number of sent OSI address negotiation protocol packets.
·     RECV_OSICP_PROT_REJ—Number of received OSI address negotiation protocol reject packets.
·     SEND_OSICP_TERM_REQ—Number of sent OSI address negotiation termination request packets.
·     RECV_OSICP_TERM_REQ—Number of received OSI address negotiation termination request packets.
·     SEND_OSICP_TERM_ACK—Number of sent OSI address negotiation termination ACK packets.
·     RECV_OSICP_TERM_ACK—Number of received OSI address negotiation termination ACK packets.
·     SEND_OSICP_FAIL—Number of sent OSI address negotiation failure packets.
MPLSCP
MPLSCP packet statistics.
·     SEND_MPLSCP_CON_REQ—Number of sent MPLS address negotiation request packets.
·     RECV_MPLSCP_CON_REQ—Number of received MPLS address negotiation request packets.
·     SEND_MPLSCP_CON_NAK—Number of sent MPLS address negotiation NAK packets.
·     RECV_MPLSCP_CON_NAK—Number of received MPLS address negotiation NAK packets.
·     SEND_MPLSCP_CON_REJ—Number of sent MPLS address negotiation reject packets.
·     RECV_MPLSCP_CON_REJ—Number of received MPLS address negotiation reject packets.
·     SEND_MPLSCP_CON_ACK—Number of sent MPLS address negotiation ACK packets.
·     RECV_MPLSCP_CON_ACK—Number of received MPLS address negotiation ACK packets.
·     SEND_MPLSCP_CODE_REJ—Number of sent MPLS address negotiation code reject packets.
·     RECV_MPLSCP_CODE_REJ—Number of received MPLS address negotiation code reject packets.
·     SEND_MPLSCP_PROT_REJ—Number of sent MPLS address negotiation protocol packets.
·     RECV_MPLSCP_PROT_REJ—Number of received MPLS address negotiation protocol reject packets.
·     SEND_MPLSCP_TERM_REQ—Number of sent MPLS address negotiation termination request packets.
·     RECV_MPLSCP_TERM_REQ—Number of received MPLS address negotiation termination request packets.
·     SEND_MPLSCP_TERM_ACK—Number of sent MPLS address negotiation termination ACK packets.
·     RECV_MPLSCP_TERM_ACK—Number of received MPLS address negotiation termination ACK packets.
·     SEND_MPLSCP_FAIL—Number of sent MPLS address negotiation failure packets.
AUTH
Authentication packet statistics.
·     SEND_PAP_AUTH_REQ—Number of sent PAP authentication request packets.
·     RECV_PAP_AUTH_REQ—Number of received PAP authentication request packets.
·     SEND_PAP_AUTH_ACK—Number of sent PAP authentication ACK packets.
·     RECV_PAP_AUTH_ACK—Number of received PAP authentication ACK packets.
·     SEND_PAP_AUTH_NAK—Number of sent PAP authentication NAK packets.
·     RECV_PAP_AUTH_NAK—Number of received PAP authentication NAK packets.
·     SEND_CHAP_AUTH_CHALLENGE—Number of sent CHAP authentication request packets.
·     RECV_CHAP_AUTH_CHALLENGE—Number of received CHAP authentication request packets.
·     SEND_CHAP_AUTH_RESPONSE—Number of sent CHAP authentication response packets.
·     RECV_CHAP_AUTH_RESPONSE—Number of received CHAP authentication response packets.
·     SEND_CHAP_AUTH_ACK—Number of sent CHAP authentication ACK packets.
·     RECV_CHAP_AUTH_ACK—Number of received CHAP authentication ACK packets.
·     SEND_CHAP_AUTH_NAK—Number of sent CHAP authentication NAK packets.
·     RECV_CHAP_AUTH_NAK—Number of received CHAP authentication NAK packets.
·     SEND_PAP_AUTH_FAIL—Number of sent PAP authentication failure packets.
·     SEND_CHAP_AUTH_FAIL—Number of sent CHAP authentication failure packets.
Use interface virtual-template to create a VT interface and enter its view, or enter the view of an existing VT interface.
Use undo interface virtual-template to remove a VT interface.
interface virtual-template number
undo interface virtual-template number
No VT interfaces exist.
number: Specifies a VT interface by its number. The value range for this argument is 0 to 1023.
To remove a VT interface, make sure all the corresponding VA interfaces are removed and the VT interface is not in use.
# Create interface Virtual-Template 10.
Use ip address ppp-negotiate to enable IP address negotiation on an interface, so that the interface can accept the IP address allocated by the server.
Use undo ip address ppp-negotiate to restore the default.
IP address negotiation is disabled on an interface.
Interface view
If you execute the ip address ppp-negotiate and ip address commands multiple times, the most recent configuration takes effect.
# Enable IP address negotiation on Serial 1/2/0/1:0.
[Sysname] interface serial 1/2/0/1:0
[Sysname-Serial1/2/0/1:0] ip address ppp-negotiate
# Enable IP address negotiation on Virtual-Template 1.
[Sysname-Virtual-Template1] ip address ppp-negotiate
ip address (Layer 3—IP Services Command Reference)
remote address
ip pool
Use ip pool to configure a PPP address pool.
Use undo ip pool to remove a PPP address pool or an IP address range of the PPP address pool.
ip pool pool-name start-ip-address [ end-ip-address ] [ group group-name ]
undo ip pool pool-name [ start-ip-address [ end-ip-address ] ]
No PPP address pool is configured.
pool-name: Specifies a name for the PPP address pool to be created, a case-sensitive string of 1 to 63 characters.
start-ip-address [ end-ip-address ]: Specifies an IP address range. If you do not specify the end-ip-address argument, the PPP address pool has only the start IP address.
group group-name: Specifies a group by its name to which the PPP address pool belongs. The group name is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the group name is default (the default group).
The system supports multiple address spaces that each correspond to a VPN instance. The same IP addresses can exist in different address spaces.
Each address space is represented by a group. One group can contain multiple PPP address pools, but one PPP address pool can belong to only one group.
One PPP address pool can contain multiple IP address ranges. You can execute this command multiple times to specify multiple IP address ranges for a PPP address pool. A PPP address pool can contain a maximum of 65535 IP addresses, and so can an IP address range.
IP address ranges in different groups can be overlapping, but those in the same group cannot.
Changes to a PPP address pool do not affect assigned IP addresses. For example, if you delete a PPP address pool from which an IP address has been assigned, the IP address can still be used.
When assigning IP address to users through a PPP address pool, make sure the PPP address pool excludes the gateway IP address of the PPP address pool.
# Configure PPP address pool aaa that contains IP addresses 129.102.0.1 through 129.102.0.10 for group a.
[Sysname] ip pool aaa 129.102.0.1 129.102.0.10 group a
display ip pool
ip pool gateway
Use ip pool gateway to configure a gateway address for a PPP address pool.
Use undo ip pool gateway to remove the gateway address for the specified PPP address pool.
ip pool pool-name gateway ip-address  [ vpn-instance vpn-instance-name ]
undo ip pool pool-name gateway
A PPP address pool is not configured with a gateway address.
pool-name: Specifies an existing PPP address pool by its name, a case-sensitive string of 1 to 63 characters.
ip-address: Specifies a gateway address for the PPP address pool.
vpn-instance vpn-instance-name: Specifies an existing MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the specified gateway belongs to the public network.
An interface on a BRAS must have an IP address before it can assign an IP address from a PPP or DHCP address pool to a client. This command enables interfaces that have no IP address to use a gateway address for IPCP negotiation and address allocation.
When you configure a gateway address for a PPP address pool, follow these restrictions and guidelines:
·     If you also specify an IP address for an interface, the interface uses its own IP address to perform IPCP negotiation.
·     You can specify only one gateway address for a PPP address pool. Different PPP address pools must have different gateway addresses (different combinations of ip-address and vpn-instance-name).
·     You can specify any gateway address for a PPP address pool.
# Specify gateway address 1.1.1.1 for PPP address pool aaa.
[Sysname] ip pool aaa gateway 1.1.1.1
ip pool
link-protocol ppp
Use link-protocol ppp to enable PPP encapsulation on an interface.
link-protocol ppp
PPP encapsulation is enabled on all interfaces except Ethernet or VLAN interfaces.
Interface view
# Enable PPP encapsulation on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] link-protocol ppp
mtu
Use mtu to set the MTU size of an interface.
mtu size
undo mtu
The MTU size is 1500.
VT interface view
size: Specifies the MTU size. The value range for this argument is 128 to 1500.
The MTU size setting of an interface affects the fragmentation and reassembly of IP packets on that interface.
For the configured MTU size to take effect, you must execute the shutdown command and then the undo shutdown command on the interface.
# Set the MTU size of Virtual-Template 10 to 1400 bytes.
[Sysname-Virtual-Template10] mtu 1400
# Set the MTU size of MP-group 1/2/1 to 1200 bytes.
[Sysname-MP-group1/2/1] mtu 1200
nas-port-type
Use nas-port-type to configure the NAS-Port-Type attribute on a VT interface.
Use undo nas-port-type to restore the default.
nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax |  hdlc |idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
undo nas-port-type
The NAS-Port-Type attribute is determined by the service type and link type of the PPP user, as shown in Table 8.
Table 8 Default NAS-Port-Type attribute
Service type
PPPoE
ethernet
L2TP
virtual
VT interface view
802.11: Specifies IEEE 802.11. The code value is 19.
adsl-cap: Specifies asymmetric DSL, Carrierless Amplitude Phase. The code value is 12.
adsl-dmt: Specifies asymmetric DSL, Discrete Multi-Tone. The code value is 13.
async: Specifies async. The code value is 0.
cable: Specifies cable. The code value is 17.
ethernet: Specifies Ethernet. The code value is 15.
g.3-fax: Specifies G.3 Fax. The code value is 10.
hdlc: Specifies HDLC Clear Channel. The code value is 7.
idsl: Specifies ISDN Digital Subscriber Line. The code value is 14.
isdn-async-v110: Specifies ISDN Async V.110. The code value is 4.
isdn-async-v120: Specifies ISDN Async V.120. The code value is 3.
isdn-sync: Specifies ISDN Sync. The code value is 2.
piafs: Specifies PHS Internet Access Forum Standard. The code value is 6.
sdsl: Specifies symmetric DSL. The code value is 11.
sync: Specifies sync. The code value is 1.
virtual: Specifies virtual. The code value is 5.
wireless-other: Specifies wireless–other. The code value is 18.
x.25: Specifies X.25. The code value is 8.
x.75: Specifies X.75. The code value is 9.
xdsl: Specifies Digital Subscriber Line of unknown type. The code value is 16.
The NAS-Port-Type attribute is used for RADIUS authentication and accounting. For more information about the NAS-Port-Type attribute, see RFC 2865.
This command does not affect existing users.
# Set the NAS-Port-Type attribute to sync for Virtual-Template 1.
[Sysname-Virtual-Template1] nas-port-type sync
ppp accm
Use ppp accm to set the ACCM value sent to the peer on an interface.
Use undo ppp accm to restore the default.
ppp accm hex-number
undo ppp accm
The ACCM value sent to the peer is 0x000A0000 on an interface.
Interface view
hex-number: Specifies an ACCM value in hexadecimal format, in the range of 0 to 0xFFFFFFFF.
ACCM negotiation only applies to asynchronous links.
# Set the ACCM value sent to the peer to 0x01010101 on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp accm 01010101
Use ppp access-user log enable to enable PPP user logging.
Use undo ppp access-user log enable to disable PPP user logging.
ppp access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
undo ppp access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
Logging is disabled for PPP users.
abnormal-logout: Specifies abnormal logout logs.
failed-login: Specifies login failure logs.
normal-logout: Specifies normal logout logs.
successful-login: Specifies login success logs.
IMPORTANT
IMPORTANT:
Typically, disable this feature to prevent excessive PPP log output.
The PPP user logging feature enables the device to generate PPP logs and send them to the information center. Logs are generated after a user comes online, goes offline, or fails to come online. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see System Management Configuration Guide.
When you execute this command without specifying any keyword, this command enables or disables logging for login successes, login failures, normal logouts, and abnormal logouts.
# Enable PPP user logging.
[Sysname] ppp access-user log enable
Use ppp account-statistics enable to enable PPP accounting on an interface.
Use undo ppp account-statistics enable to disable PPP accounting on an interface.
ppp account-statistics enable  [ acl { acl-number | name acl-name } ]
PPP accounting is disabled on an interface.
Interface view
acl: Specifies an ACL to match traffic. If no ACL is specified, the device generates statistics for all PPP traffic.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999, where:
·     2000 to 2999 are numbers for basic IPv4 and IPv6 ACLs.
·     3000 to 3999 are numbers for advanced IPv4 and IPv6 ACLs.
If the specified ACL number corresponds to an IPv4 ACL and an IPv6 ACL, both ACLs take effect.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters that start with an alphabetical character. To avoid confusion, do not use all as an ACL name.
When specifying an ACL, follow these restrictions and guidelines:
·     If the specified ACL does not exist or does not have any rules, the PPP accounting feature does not take effect.
·     In a specified ACL, if a rule has the vpn-instance keyword specified, the rule takes effect only on VPN packets. If a rule does not have the vpn-instance keyword specified, the rule takes effect only on packets in the public network.
# Enable PPP accounting on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp account-statistics enable
# Enable PPP accounting on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp account-statistics enable
Use ppp acfc local-request to configure an interface to send ACFC requests by including the ACFC option in outbound LCP negotiation requests.
Use undo ppp acfc local-request to restore the default.
An interface does not include the ACFC option in outbound LCP negotiation requests.
Interface view
# Configure Serial 1/2/0/1:0 to send ACFC requests to the peer in PPP negotiation.
[Sysname-Serial1/2/0/1:0] ppp acfc local-request
# Configure Virtual-Template 1 to send ACFC requests to the peer in PPP negotiation.
[Sysname-Virtual-Template1] ppp acfc local-request
Use ppp acfc remote-reject to configure an interface to reject ACFC requests received from the remote peer.
Use undo ppp acfc remote-reject to restore the default.
An interface accepts ACFC requests received from the remote peer, and it performs ACFC on frames sent to the peer.
Interface view
# Configure Serial 1/2/0/1:0 to reject ACFC requests received from the remote peer.
[Sysname-Serial1/2/0/1:0] ppp acfc remote-reject
# Configure Virtual-Template 1 to reject ACFC requests received from the remote peer.
[Sysname-Virtual-Template1] ppp acfc remote-reject
Use ppp authentication-mode to configure PPP authentication on an interface.
Use undo ppp authentication-mode to restore the default.
ppp authentication-mode { chap | ms-chap | ms-chap-v2 | pap } * [ [ call-in ] domain { isp-name | default enable isp-name } ]
PPP authentication is disabled on an interface.
Interface view
chap: Uses CHAP authentication.
ms-chap: Uses MS-CHAP authentication.
ms-chap-v2: Uses MS-CHAP-V2 authentication.
pap: Uses PAP authentication.
call-in: Authenticates the call-in users only. This keyword can be configured when the local end acts as the receiving end of DDR calls. For more information about DDR, see Layer 2WAN Access Configuration Guide.
domain isp-name: Specifies the ISP domain name for authentication, a case-insensitive string of 1 to 255 characters. The ISP domain name cannot be d, de, def, defa, defau, defaul, or default.
default enable isp-name: Specifies the default ISP domain name for authentication, a case-insensitive string of 1 to 255 characters.
PPP authentication includes the following categories:
·     PAP—Two-way handshake authentication. The password is in plain text or cipher text.
·     CHAP—Three-way handshake authentication. The password is in plain text or cipher text.
·     MS-CHAP—Three-way handshake authentication. The password is in cipher text.
·     MS-CHAP-V2—Three-way handshake authentication. The password is in cipher text.
You can configure multiple authentication modes.
In any PPP authentication mode, AAA determines whether a user can pass the authentication through a local authentication database or an AAA server. For more information about AAA authentication, see User Access and Authentication Configuration Guide.
If multiple ISP domains are available, the ISP domains are used in the following order:
1.     ISP domain specified by the domain isp-name option in this command.
2.     ISP domain contained in the username.
3.     ISP domain specified by the domain default enable isp-name option in this command.
4.     ISP domain selected by the AAA module. For more information about AAA, see User Access and Authentication Configuration Guide.
For authentication on a dialup interface, configure authentication on both the physical interface and the dialer interface. When a physical interface receives a DDR call request, it first initiates PPP negotiation and authenticates the dial-in user. Then it passes the call to the upper layer protocol.
# Configure Serial 1/2/0/1:0 to authenticate the peer by using PAP.
[Sysname-Serial1/2/0/1:0] ppp authentication-mode pap
# Configure Serial 1/2/0/1:0 to authenticate the peer by using PAP, CHAP, and MS-CHAP.
[Sysname-Serial1/2/0/1:0] ppp authentication-mode pap chap ms-chap
# Configure Virtual-Template 1 to authenticate the peer by using PAP.
[Sysname-Virtual-Template1] ppp authentication-mode pap
# Configure Virtual-Template 1 to authenticate the peer by using PAP and CHAP.
[Sysname-Virtual-Template1] ppp authentication-mode pap chap
domain default (User Access and Authentication Command Reference)
local-user (User Access and Authentication Command Reference)
ppp chap password
ppp chap user
ppp pap local-user
ppp chap password
Use ppp chap password to set the password for CHAP authentication on an interface.
Use undo ppp chap password to restore the default.
ppp chap password { cipher | simple } string
No password is set for CHAP authentication on an interface.
Interface view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 255 characters. Its encrypted form is a case-sensitive string of 1 to 373 characters.
# Set the password for CHAP authentication to plaintext password sysname on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp chap password simple sysname
# Set the password for CHAP authentication to plaintext password sysname on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp chap password simple sysname
ppp chap user
Use ppp chap user to set the username for CHAP authentication on an interface.
Use undo ppp chap user to restore the default.
ppp chap user username
undo ppp chap user
The username for CHAP authentication is null on an interface.
Interface view
username: Specifies the username for CHAP authentication, a case-sensitive string of 1 to 80 characters. The username is sent to the peer for the local device to be authenticated.
To pass CHAP authentication, the username/password of one side must be the local username/password on the peer.
# Set the username for CHAP authentication to Root on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp chap user Root
# Set the username for CHAP authentication to Root on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp chap user Root
Use ppp compression iphc enable to enable IPHC on an interface.
Use undo ppp compression iphc enable to disable IPHC on an interface.
ppp compression iphc enable [ nonstandard ]
IPHC is disabled on an interface.
Interface view
nonstandard: Specifies the nonstandard encapsulation format. If you do not specify this keyword, packets are encapsulated in standard format. You must specify this keyword when the device communicates with a third-party device. If you specify this keyword, this command enables RTP header compression.
IPHC includes RTP header compression and TCP header compression.
Enabling or disabling IPHC enables or disables both RTP header compression and TCP header compression.
To use IPHC, you must enable it on both sides of a PPP link.
When you enable IPHC on a VT, dialer, or ISDN interface, the setting does not immediately take effect. For the setting to take effect, execute the shutdown and then undo shutdown commands on the interface or its bound physical interface.
# Enable IPHC on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp compression iphc enable
# Enable IPHC on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp compression iphc enable
Use ppp compression iphc rtp-connections to set the maximum number of connections for which an interface can perform RTP header compression.
Use undo ppp compression iphc rtp-connections to restore the default.
ppp compression iphc rtp-connections number
An interface can perform RTP header compression for a maximum of 16 connections.
Interface view
number: Specifies the maximum number of connections for which an interface can perform RTP header compression. The value range for this argument is 3 to 1000:
·     When the number argument is set to a value less than or equal to 256, packets are compressed in the format of COMPRESSED RTP 8.
·     When the number argument is set to a value greater than 256, packets are compressed in the format of COMPRESSED RTP 16.
RTP is a connection-oriented protocol. An interface can accommodate multiple RTP connections.
RTP header compression occupies memory resources for maintaining connection information. This command can limit memory resources used by compression. For example, if you set the limit to 3, RTP header compression only applies to a maximum of three RTP connections.
After you execute this command, you must shut down and then bring up the interface to make the command take effect.
You can execute this command only when IPHC is enabled. The configuration is removed after IPHC is disabled.
# Set the maximum number of connections for which Serial 1/2/0/1:0 can perform RTP header compression to 10.
[Sysname-Serial1/2/0/1:0] ppp compression iphc rtp-connections 10
# Set the maximum number of connections for which Virtual-Template 1 can perform RTP header compression to 10.
[Sysname-Virtual-Template1] ppp compression iphc rtp-connections 10
Use ppp compression iphc tcp-connections to set the maximum number of connections for which an interface can perform TCP header compression.
Use undo ppp compression iphc tcp-connections to restore the default.
ppp compression iphc tcp-connections number
An interface can perform TCP header compression for a maximum of 16 connections.
Interface view
number: Specifies the maximum number of connections for which an interface can perform TCP header compression. The value range for this argument is 3 to 256.
TCP is a connection-oriented protocol. A link can accommodate multiple TCP connections.
TCP header compression occupies memory resources for maintaining connection information. This command can limit memory resources used by compression. For example, if you set the limit to 3, TCP header compression only applies to a maximum of three TCP connections.
You can execute this command only when IPHC is enabled and packets are encapsulated in standard format. The configuration is removed after IPHC is disabled or packets are encapsulated in nonstandard format.
# Set the maximum number of connections for which Serial 1/2/0/1:0 can perform TCP header compression to 10.
[Sysname-Serial1/2/0/1:0] ppp compression iphc tcp-connections 10
# Set the maximum number of connections for which Virtual-Template 1 can perform TCP header compression to 10.
[Sysname-Virtual-Template1] ppp compression iphc tcp-connections 10
ppp ipcp dns
Use ppp ipcp dns to configure the primary and secondary DNS server IP addresses to be allocated in PPP negotiation on an interface.
Use undo ppp ipcp dns to delete the primary and secondary DNS server IP addresses to be allocated in PPP negotiation on an interface.
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
undo ppp ipcp dns primary-dns-address [ secondary-dns-address ]
The DNS server IP addresses to be allocated in PPP negotiation are not configured on an interface.
Interface view
primary-dns-address: Specifies a primary DNS server IP address.
secondary-dns-address: Specifies a secondary DNS server IP address.
A device can assign DNS server IP addresses to its peer during PPP negotiation when the peer initiates requests.
To check the allocated DNS server IP addresses, execute the winipcfg or ipconfig /all command on the host.
# Set the primary and secondary DNS server IP addresses to 100.1.1.1 and 100.1.1.2 for the peer on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp ipcp dns 100.1.1.1 100.1.1.2
# Set the primary and secondary DNS server IP addresses to 100.1.1.1 and 100.1.1.2 for the peer on Virtual-Template 1.
[Sysname] interface virtual-template 1
[Sysname-Virtual-Template1] ppp ipcp dns 100.1.1.1 100.1.1.2
ppp ipcp dns admit-any
Use ppp ipcp dns admit-any to configure an interface to accept the DNS server IP addresses assigned by the peer even though it does not request DNS server IP addresses from the peer.
Use undo ppp ipcp dns admit-any to restore the default.
An interface does not accept the DNS server IP addresses assigned by the peer if it does not request DNS server IP addresses from the peer.
Interface view
You can configure an interface to accept the DNS server IP addresses assigned by the peer, through which domain names can be resolved for the device.
Typically, the server assigns a DNS server address to a client in PPP negotiation only when the client is configured with the ppp ipcp dns request command. Some servers, however,  forcibly assign DNS server addresses to clients. You must execute the ppp ipcp dns admit-any command on the client devices to accept the DNS server addresses.
# Configure Serial 1/2/0/1:0 to accept DNS server IP addresses allocated by the peer.
[Sysname-Serial1/2/0/1:0] ppp ipcp dns admit-any
# Configure Virtual-Template 1 to accept DNS server IP addresses allocated by the peer.
[Sysname-Virtual-Template1] ppp ipcp dns admit-any
Use ppp ipcp dns request to enable an interface to actively request the DNS server IP address from its peer.
Use undo ppp ipcp dns request to restore the default.
An interface does not actively request the DNS server IP address from its peer.
Interface view
If a device is connected to a provider's access server through a PPP link, you can use this command. Then, the device can obtain the specified DNS server IP address from the access server during IPCP negotiation.
You can check the DNS server IP addresses by displaying information about the interface.
# Enable Serial 1/2/0/1:0 to actively request the DNS server IP address from its peer.
[Sysname-Serial1/2/0/1:0] ppp ipcp dns request
# Enable Virtual-Template 1 to actively request the DNS server IP address from its peer.
[Sysname-Virtual-Template1] ppp ipcp dns request
ppp ipcp remote-address match
Use ppp ipcp remote-address match to enable the IP segment match feature for PPP IPCP negotiation on an interface.
Use undo ppp ipcp remote-address match to restore the default.
The IP segment match feature is disabled for PPP IPCP negotiation on an interface.
Interface view
This command enables the local interface to check whether its IP address and the IP address of the remote interface are in the same network segment. If they are not, IPCP negotiation fails.
# Enable the IP segment match feature on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp ipcp remote-address match
ppp ip-pool route
Use ppp ip-pool route to configure a PPP address pool route.
Use undo ppp ip-pool route to remove a PPP address pool route.
ppp ip-pool route ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
undo ppp ip-pool route ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
No PPP address pool route is configured.
ip-address: Specifies the destination IP address of the PPP address pool route, in dotted decimal notation.
mask-length: Specifies a mask length for the IP address, in the range of 0 to 32.
mask: Specifies a mask for the IP address, in dotted decimal notation.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the PPP address pool route applies to the public network.
The BRAS uses PPP address pool routes to control downlink traffic forwarding.
After you configure a PPP address pool route, the BRAS generates a static blackhole route destined for the specified network. All traffic matching the blackhole route is discarded. When a legal user logs in, the BRAS adds a host route destined for the specified network. In addition, the BRAS uses a dynamic routing protocol to redistribute the PPP address pool route to the upstream device.
Figure 1 Network diagram for the PPP address pool route
Make sure the destination network of the PPP address pool route includes the PPP address pool. You can execute this command multiple times to configure multiple PPP address pool routes.
# Configure the PPP address pool route as 2.2.2.2/24.
[Sysname] ppp ip-pool route 2.2.2.2 24
ppp lcp delay
Use ppp lcp delay to set the LCP negotiation delay timer.
Use undo ppp lcp delay to restore the default.
ppp lcp delay milliseconds
undo ppp lcp delay
PPP starts LCP negotiation immediately after the physical layer comes up.
Interface view
milliseconds: Specifies the LCP negotiation delay timer in the range of 1 to 10000 milliseconds.
If two ends of a PPP link vary greatly in the LCP negotiation packet processing rate, execute this command on the end with a higher processing rate. The LCP negotiation delay timer prevents frequent LCP negotiation packet retransmission. After the physical layer comes up, PPP starts LCP negotiation when the delay timer expires. If PPP receives LCP negotiation packets before the delay timer expires, it starts LCP negotiation immediately.
# Set the LCP negotiation delay timer to 130 milliseconds.
[Sysname-Virtual-Template1] ppp lcp delay 130
ppp lqm
Use ppp lqm to enable PPP link quality Monitoring (LQM) on an interface.
Use undo ppp lqm to disable PPP LQM on an interface.
ppp lqm close-percentage close-percentage [ resume-percentage resume-percentage ]
undo ppp lqm
PPP LQM is disabled on an interface.
Interface view
close-percentage close-percentage: Specifies the PPP LQM close percentage in the range of 0 to 100.
resume-percentage resume-percentage: Specifies the PPP LQM resume percentage in the range of 0 to 100. The resume percentage must be greater than or equal to the close percentage. The default resume percentage is equal to the close percentage.
If you enable PPP LQM on both sides of a PPP link, make sure both sides have the same PPP LQM settings. Typically, there is no need to enable PPP LQM on both sides of a PPP link.
As a best practice, do not enable PPP LQM on a DDR dial-up link because DDR tears the link down when the link is closed by LQM. Then LQM cannot send LQR packets to resume the link.
# Enable PPP LQM on Serial 1/2/0/1:0, and set the PPP LQM close percentage to 90 and resume percentage to 95.
[Sysname-Serial1/2/0/1:0] ppp lqm close-percentage 90 resume-percentage 95
ppp lqm lcp-echo
Use ppp lqm lcp-echo to configure an interface to periodically send LCP echo packets when LQM detects a low quality link.
Use undo ppp lqm lcp-echo to restore the default.
ppp lqm lcp-echo [ packet size ] [ interval interval]
An interface does not send LCP echo packets when LQM detects a low quality link.
Interface view
packet size: Specifies the size added for the LCP echo packet, in the range of 128 to 1500 bytes. The default value is 0 bytes. For example, if you set the size argument to 1400, the LCP echo packet sent is 1400 bytes larger than the original length.
interval interval: Specifies the interval for sending LCP echo packets, in the range of 1 to 10 seconds. The default value is 10 seconds.
This feature can avoid PPP link flapping caused by loss of large LCP packets.
# Configure Serial 1/2/0/1:0 to send a LCP echo packet every 1 second. The LCP echo packet is 1400 bytes larger than the original length.
[Sysname-Serial1/2/0/1:0] ppp lqm lcp-echo packet 1400 interval 1
ppp pap local-user
Use ppp pap local-user to set the local username and password for PAP authentication on an interface.
Use undo ppp pap local-user to restore the default.
ppp pap local-user username password { cipher | simple } string
The local username and password for PAP authentication are blank on an interface.
Interface view
username: Specifies the username of the local device for PAP authentication, a case-sensitive string of 1 to 80 characters.
For the local device to pass PAP authentication on the peer, make sure the username and password configured for the local device are also configured on the peer. You can configure the peer's username and password by using the local-user username and password { cipher | simple } string commands, respectively.
# Set the local username and password for PAP authentication to user1 and plaintext pass1 on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp pap local-user user1 password simple pass1
# Set the local username and password for PAP authentication to user1 and plaintext pass1 on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp pap local-user user1 password simple pass1
password (User Access and Authentication Command Reference)
ppp pfc local-request
Use ppp pfc local-request to configure an interface to send PFC requests by including the PFC option in outbound LCP negotiation requests.
Use undo ppp pfc local to restore the default.
undo ppp pfc local-request
An interface does not include the PFC option in outbound LCP negotiation requests.
Interface view
# Configure Serial 1/2/0/1:0 to send PFC requests during PPP negotiation.
[Sysname-Serial1/2/0/1:0] ppp pfc local-request
# Configure Virtual-Template 1 to send PFC requests during PPP negotiation.
[Sysname-Virtual-Template1] ppp pfc local-request
ppp pfc remote-reject
Use ppp pfc remote-reject to configure an interface to reject PFC requests received from the remote peer.
Use undo ppp pfc remote to restore the default.
undo ppp pfc remote-reject
An interface accepts PFC requests received from the remote peer, and it performs PFC on frames sent to the peer.
Interface view
# Configure Serial 1/2/0/1:0 to reject PFC requests received from the remote peer.
[Sysname-Serial1/2/0/1:0] ppp pfc remote-reject
# Configure Virtual-Template 1 to reject PFC requests received from the remote peer.
[Sysname-Virtual-Template1] ppp pfc remote-reject
ppp timer negotiate
Use ppp timer negotiate to set the PPP negotiation timeout time on an interface.
Use undo ppp timer negotiate to restore the default.
ppp timer negotiate seconds
The PPP negotiation timeout time is 3 seconds on an interface.
Interface view
seconds: Specifies the negotiation timeout time in the range of 1 to 10 seconds.
In PPP negotiation, if the local device receives no response from the peer during the timeout time after it sends a packet, the local device sends the last packet again.
# Set the PPP negotiation timeout time to 5 seconds on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp timer negotiate 5
# Set the PPP negotiation timeout time to 5 seconds on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp timer negotiate 5
remote address
Use remote address to configure an interface to assign an IP address to the client.
Use undo remote address to restore the default.
remote address { ip-address | pool pool-name }
undo remote address
An interface does not assign an IP address to the client.
Interface view
ip-address: Specifies the IP address to be assigned to the client.
pool pool-name: Specifies a PPP or DHCP address pool by its name from which an IP address is assigned to the client. The pool name is a case-sensitive string of 1 to 63 characters.
This command can be used when the local interface is configured with an IP address, but the peer has no IP address. To enable the peer to accept the IP address assigned by the local interface (server), you must execute the ip address ppp-negotiate command on the peer to make the peer act as a client.
This command enables the local interface to forcibly assign an IP address to the peer. If the peer is not configured with the ip address ppp-negotiate command but configured with an IP address, the peer will not accept the assigned IP address. This results in an IPCP negotiation failure.
PPP supports IP address assignment from a PPP or DHCP address pool, but the PPP address pool takes precedence over the DHCP address pool. For example, if you use a pool name that identifies both a PPP address pool and a DHCP address pool, the system uses only the PPP address pool for address assignment.
To make the configuration of the remote address command take effect, execute this command before the ip address command, which triggers IPCP negotiation. If you execute the remote address command after the ip address command, the server assigns an IP address to the client during the next IPCP negotiation.
After you use the remote address command to assign an IP address to the client, you can execute the remote address command again or the undo remote address command for the peer. However, the new configuration does not take effect until the next IPCP negotiation.
# Specify the IP address to be assigned to the client as 10.0.0.1 on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] remote address 10.0.0.1
# Configure Serial 1/2/0/1:0 to assign an IP address from address pool aaa to the client.
[Sysname-Serial1/2/0/1:0] remote address pool aaa
# Specify the IP address to be assigned to the client as 10.0.0.1 on Virtual-Template 1.
[Sysname-Virtual-Template1] remote address 10.0.0.1
# Configure Virtual-Template 1 to assign an IP address from address pool aaa to the client.
[Sysname-Virtual-Template1] remote address pool aaa
ip pool
remote address dhcp client-identifier
Use remote address dhcp client-identifier username to configure the DHCP client IDs for PPP users acting as DHCP clients.
Use undo remote address dhcp client-identifier to restore the default.
remote address dhcp client-identifier { callingnum | username }
No DHCP client IDs are configured for PPP users acting as DHCP clients.
Interface view
callingnum: Uses the calling numbers as the DHCP client IDs. The calling numbers are carried in the calling number AVPs in L2TP negotiation packets. A calling number is formed by the user MAC address and the VLAN to which the user belongs. For example, if the MAC address of a user is 000f-e235-dc71, and the inner VLAN and outer VLAN of the user are VLAN 1 and VLAN 2, respectively, the calling number of the user is 000f-e235-dc71-00010002.
username: Uses the PPP usernames as the DHCP client IDs.
By default, a PPP client randomly selects a DHCP client ID when the PPP client requests an IP address through DHCP. In this case, the DHCP server cannot assign specific IP addresses to specific clients based on client IDs. For the DHCP server to assign specific IP addresses to specific clients based on client IDs, use this command to configure the calling numbers or usernames as the DHCP client IDs.
When PPP usernames are used as the DHCP client IDs, make sure different users use different PPP usernames to come online.
# Use the PPP usernames as the DHCP client IDs for PPP users acting as DHCP clients on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] remote address dhcp client-identifier username
# Use the PPP usernames as the DHCP client IDs for PPP users acting as DHCP clients on Virtual-template 1.
[Sysname-Virtual-Template1] remote address dhcp client-identifier username
reset counters interface virtual-access
Use reset counters interface virtual-access to clear statistics on VA interfaces.
reset counters interface [ virtual-access [ interface-number ] ]
virtual-access: Clears statistics on VA interfaces.
interface-number: Specifies an existing VA interface by its number.
Before collecting traffic statistics regularly on a VA interface, clear the existing statistics.
If you do not specify the virtual-access keyword, the command clears statistics on all interfaces.
If you specify the virtual-access keyword without the interface-number argument, the command clears statistics on all VA interfaces.
If you specify both virtual-access and interface-number, the command clears statistics on the specified VA interface.
# Clear statistics on Virtual-Access 10.
<Sysname> reset counters interface virtual-access 10
display interface virtual-access
reset ppp access-user
Use reset ppp access-user to log off a PPP user.
reset ppp access-user { ip-address ipv4-address  [ vpn-instance ipv4-vpn-instance-name ] | ipv6-address ipv6-address [ vpn-instance ipv6-vpn-instance-name ]  | username user-name }
ip-address ipv4-address: Specifies a PPP user by its IPv4 address.
ipv6-address ipv6-address: Specifies a PPP user by its IPv6 address.
vpn-instance ipv4-vpn-instance-name: Specifies a PPP user by the VPN to which the user belongs. The ipv4-vpn-instance-name argument specifies the name of the IPv4 MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the specified user belongs to the public network.
vpn-instance ipv6-vpn-instance-name: Specifies a PPP user by the VPN to which the user belongs. The ipv6-vpn-instance-name argument specifies the name of the IPv6 MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the specified user belongs to the public network.
username user-name: Specifies a PPP user by username, a case-sensitive string of 1 to 80 characters.
This command takes effect only on the current login for an online BRAS user, for example, PPPoE or L2TP user. The user can come online after it is logged off.
# Log off the PPP user at 192.168.100.2.
<Sysname> reset ppp access-user ip-address 192.168.100.2
display ppp access-user
reset ppp compression iphc
Use reset ppp compression iphc to clear IPHC statistics.
reset ppp compression iphc [ rtp | tcp ] [ interface interface-type interface-number ]
rtp: Clears IPHC RTP header compression statistics.
tcp: Clears IPHC TCP header compression statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command clears IPHC statistics on all interfaces.
If neither rtp nor tcp is specified, this command clears both RTP header compression and TCP header compression statistics.
# Clear IPHC statistics on all interfaces.
<Sysname> reset ppp compression iphc
reset ppp packet statistics
Use reset ppp packet statistics to clear PPP negotiation packet statistics.
reset ppp packet statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears PPP negotiation packet statistics for all cards.
# Clear PPP negotiation packet statistics for the specified slot.
<Sysname> reset ppp packet statistics slot 2
timer-hold
Use timer-hold to set the keepalive interval on an interface.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds on an interface.
Interface view
seconds: Specifies the interval for sending keepalive packets, in the range of 0 to 32767 seconds. The value 0 disables an interface from sending keepalive packets. In this case, the interface can respond to keepalive packets from the peer.
An interface sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface receives no response to keepalive packets when the keepalive retry limit is reached, it determines that the link fails and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 20 seconds on Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] timer-hold 20
# Set the keepalive interval to 20 seconds on Virtual-Template 1.
[Sysname-Virtual-Template1] timer-hold 20
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit on an interface.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5 on an interface.
Interface view
retries: Specifies the maximum number of keepalive attempts in the range of 1 to 255.
To set the keepalive interval, use the timer-hold command.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 for Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] timer-hold retry 10
# Set the keepalive retry limit to 10 for Virtual-Template 1.
[Sysname-Virtual-Template1] timer-hold retry 10
timer-hold
MP commands
display interface mp-group
Use display interface mp-group to display information about a specified MP-group interface or all MP-group interfaces.
display interface [ mp-group [ interface-number ] ] [ brief [ description | down ] ]
mp-group [ interface-number ]: Specifies an existing MP-group interface by its number. If you do not specify the mp-group keyword, the command displays information about all interfaces except VA interfaces on the device. If you specify the mp-group keyword without the interface-number argument, the command displays information about all existing MP-group interfaces.
description: Displays complete interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description if the description contains more than 27 characters.
down: Displays information about interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about all interfaces.
# Display detailed information about MP-group 1/2/1.
<Sysname> display interface mp-group 1/2/1
MP-group1/2/1
Current state: UP
Line protocol state: UP
Description: MP-group1/2/1 Interface
Bandwidth: 2048kbps
Hold timer: 10 seconds,retry times: 5
Internet address: 192.168.1.200/24 (primary)
Link layer protocol: PPP
LCP: opened, MP: opened
Physical: MP, baudrate: 2048000 bps
Last 300 seconds input rate: 0 bytes/sec, 0 packets/sec
Last 300 seconds output rate: 0 bytes/sec, 0 packets/sec
# Display brief information about MP-group 1/2/1.
<Sysname> display interface mp-group 1/2/1 brief
Protocol: (s) - spoofing
MP2/0/0              DOWN DOWN     --
# Display brief information about the MP-group interfaces in physically down state and the causes.
<Sysname> display interface mp-group brief down
MP2/0/0              ADM  Administratively
MP2/0/1              DOWN Not connected
Table 9 Command output
Current state
Physical and administrative states of the interface:
·     DOWN (Administratively)—The interface was administratively shut down with the shutdown command.
·     DOWN—The interface is administratively up but physically down (possibly because no physical link is present or the link is faulty).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state: UP or DOWN.
Interface description.
Bandwidth
Expected bandwidth of the interface.
Hold timer
Interval at which the interface sends keepalive packets.
retry times
Keepalive retry limit.
The interface determines that its peer has been down if it does not receive a keepalive response when the keepalive retry limit is reached.
The interface cannot process IP packets currently.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide
LCP negotiation is complete.
Physical
Physical type of the interface.
baudrate
Baud rate of the interface.
Traffic statistics of the interface output queues.
Last time when statistics on the interface were cleared. Never indicates that statistics on the interface were never cleared.
Average rate of input packets and output packets in the last 300 seconds.
Total number of inbound packets of the interface (in the number of packets and in bytes), and the number of dropped incoming packets.
Total number of outbound packets of the interface (in the number of packets and in bytes), and the number of dropped outgoing packets.
Brief information about Layer 3 interfaces.
Link status:
·     ADM—The interface has been administratively shut down. To recover its physical state, execute the undo shutdown command.
·     Stby—The interface is operating as a backup interface. To see the primary interface, use the display interface-backup state command in High Availability Command Reference.
Indicates the line protocol is UP, but the physical link is an on-demand link or is not present.
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWNThe interface is physically down.
·     ADM—The interface has been administratively shut down. To recover its physical state, use the undo shutdown command.
·     StbyThe interface is a backup interface.
Protocol
·     UP—The line protocol is up.
·     DOWN—The line protocol is down.
·     UP(s)—The line protocol is up, but the physical link is an on-demand link or is not present.
Primary IP
Primary IP address of the interface.
Interface description configured by using the description command. If you do not specify the description keyword, the display interface brief command displays a maximum of 27 characters of the description. If you specify the description keyword, the command displays the complete description.
Cause
Causes for the physical state of the interface to be Down:
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Administratively—The interface was shut down with the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
reset counters interface mp-group
display ppp mp
Use display ppp mp to display MP information for MP-group interfaces.
display ppp mp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its number. If you do not specify this option, the command displays MP information for all interfaces.
# Display MP information. (MP is configured through an MP-group interface.)
<Sysname> display ppp mp
Template: MP-group1/2/1
max-bind: 20, fragment: enabled, min-fragment: 128
Master link: MP-group1/2/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group1/2/1
Sequence format: short (rcv)/long (sent)
Bundle Up Time: 2012/11/05  07:29:33:612
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 0 (rcv)/0 (sent)
Active member channels: 2 members
      Serial1/2/0/1:0:15               Up-Time: 2012/11/05  07:29:33:613
      Serial1/2/0/1:0:16               Up-Time: 2012/11/05  07:30:10:945
Inactive member channels: 2 members
      Serial1/2/0/1:0:17
      Serial1/2/0/1:0:18
Table 10 Command output
max-bind
Maximum number of links that can be bound.
fragment
Indicates whether MP fragmentation is enabled or disabled.
min-fragment
Minimum size of an MP fragment.
Sequence number header format of MP. The short sequence number format is used in the incoming direction, and the long sequence number format is used in the outgoing direction.
reordered
Number of reassembled packets.
unassigned
Number of packets waiting for being reassembled.
interleaved
Number of interleaved fragments.
LFI breaks larger packets into fragments and interleaves the fragments between smaller packets for transmission.
Received sequence number/sent sequence number.
Up-Time
Uptime of a member channel.
interface mp-group
Use interface mp-group to create an MP-group interface and enter its view, or enter the view of an existing MP-group interface.
Use undo interface mp-group to remove an MP-group interface.
interface mp-group mp-number
undo interface mp-group mp-number
No MP-group interfaces exists.
mp-number: Specifies an MP-group interface by its number. The value range for this argument is 0 to 1023.
You must use the interface mp-group command together with the ppp mp mp-group command. You can execute the two commands in either order.
# Create interface MP-group 1/2/1.
[Sysname] interface mp-group 1/2/1
ppp mp
Use ppp mp to enable MP for an interface.
Use undo ppp mp to disable MP on an interface.
ppp mp
undo ppp mp
An interface is enabled with PPP.
Interface view
To obtain more bandwidth, you can bind multiple PPP links to form a logical MP interface.
# Enable MP for Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp mp
ppp mp binding-mode
Use ppp mp binding-mode to set the MP binding mode on an interface.
Use undo ppp mp binding-mode to restore the default.
ppp mp binding-mode { authentication | both | descriptor }
Both the username and the discriminator are used for MP binding on an interface.
VT interface view
Dialer interface view
authentication: Uses the username for MP binding.
both: Uses both the username and the endpoint discriminator for MP binding.
descriptor: Uses the endpoint discriminator for MP binding.
The username is obtained from the peer during PAP, CHAP, MS-CHAP, or MS-CHAP-V2 authentication. The endpoint discriminator, which uniquely identifies a device, is obtained from the peer during LCP negotiation. Based on the username or endpoint discriminator, the system can locate the corresponding VT interface and create an MP bundle according to the template.
The descriptor mode cannot differentiate users. To bind users to different bundles, use the both mode.
The authentication mode cannot differentiate peer devices. When multiple peer devices exist, use the both mode.
# Specify Virtual-Template 1 to use the username for MP binding.
[Sysname] interface virtual-template1
[Sysname-Virtual-Template1] ppp mp binding-mode authentication
ppp mp endpoint
ppp mp endpoint
Use ppp mp endpoint to set the endpoint option.
Use undo ppp mp endpoint to restore the default.
ppp mp endpoint endpoint
The endpoint option carries the device name on an interface.
Interface view
endpoint: Specifies the content of the endpoint option, a case-sensitive string of 1 to 20 characters.
The endpoint option (endpoint discriminator) is negotiated during MP LCP negotiation.
When MP is configured by using a VT interface, an MP endpoint bases its link binding decisions on the remote endpoint discriminators, and assigns the links that receive the same endpoint discriminator to the same bundle. To avoid incorrect link binding on a VT interface, make sure the link discriminators used by different devices are unique. You must reconfigure an endpoint discriminator for a device if the default endpoint discriminator (device name) cannot uniquely identify the MP bundle at the remote end.
When MP is configured by using an MP-group interface, the negotiating endpoints do not base their binding decisions on the endpoint discriminator. By default, the endpoint discriminator of an interface in an MP-group is the MP-group interface name. If you configure an endpoint discriminator for the interface, the configured MP endpoint discriminator takes effect.
If the endpoint discriminator exceeds 20 bytes, the first 20 bytes are taken as the endpoint discriminator.
# Configure the endpoint discriminator of Serial 1/2/0/1:0 as 123456.
[Sysname-Serial1/2/0/1:0] ppp mp endpoint 123456
# Configure the endpoint discriminator of Virtual-Template 1 as 123456.
[Sysname-Virtual-Template1] ppp mp endpoint 123456
ppp mp binding-mode
ppp mp fast-forward enable
Use ppp mp fast-forward enable to enable MP packet fast forwarding.
Use undo ppp mp fast-forward enable to disable MP packet fast forwarding.
MP packet fast forwarding is disabled.
VT interface view
MP-group interface view
With MP packet fast forwarding enabled on an interface, the packets sent out of the interface will carry the MP sequence numbers and fragment IDs. However, each packet is sent as a whole to improve the forwarding efficiency.
With the ppp mp fast-forward enable command executed on an interface, the ppp mp fragment disable or undo ppp mp fragment disable command no longer takes effect on that interface.
# Enable MP packet fast forwarding on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp fast-forward enable
Use ppp mp fragment disable to disable MP fragmentation on an interface.
Use undo ppp mp fragment disable to enable MP fragmentation on an interface.
MP fragmentation is enabled on an interface.
VT interface view
If the peer device does not support fragment reassembly, you must configure the ppp mp fragment disable command to disable MP fragmentation on the local device. This enables the two devices to communicate. After that, outgoing packets are not fragmented, but they still carry an MP sequence number and fragment tag.
After you execute the ppp mp fragment disable command on an interface, the settings configured with the ppp mp lfi enable and ppp mp min-fragment commands do not take effect on the interface.
# Disable MP fragmentation on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp fragment disable
ppp mp lfi enable
ppp mp min-fragment
ppp mp lfi delay-per-frag
Use ppp mp lfi delay-per-frag to set the maximum LFI fragment transmission delay on an interface.
Use undo ppp mp lfi delay-per-frag to restore the default.
ppp mp lfi delay-per-frag time
The maximum LFI fragment transmission delay is 10 ms on an interface.
VT interface view
time: Specifies the maximum LFI fragment transmission delay, in the range of 1 to 1000 ms.
# Set the maximum LFI fragment transmission delay to 20 ms on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp lfi delay-per-frag 20
ppp mp lfi enable
ppp mp lfi size-per-frag
ppp mp lfi enable
Use ppp mp lfi enable to enable LFI on an interface.
Use undo ppp mp lfi to disable LFI on an interface.
ppp mp lfi enable
undo ppp mp lfi enable
LFI is disabled on an interface.
VT interface view
Disabling LFI also removes the user-configured settings of the maximum LFI fragment transmission delay and size.
# Enable LFI on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp lfi enable
Use ppp mp lfi size-per-frag to set the maximum LFI fragment size (in bytes) on an interface.
Use undo ppp mp lfi size-per-frag to restore the default.
ppp mp lfi size-per-frag size
On an interface, the maximum LFI fragment size is derived from this formula: (Expected bandwidth of the interface x Maximum LFI fragment transmission delay)/8.
VT interface view
size: Specifies the maximum LFI fragment size in the range of 40 to 1500 bytes.
When LFI is enabled and both this command and the ppp mp lfi delay-per-frag command are configured, the maximum LFI fragment size is the value configured with the ppp mp lfi size-per-frag command.
# Set the maximum LFI fragment size to 80 bytes on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp lfi size-per-frag 80
ppp mp lfi enable
ppp mp load-sharing mode strict-round-robin
Use ppp mp load-sharing mode strict-round-robin to enable the strict load sharing mode for an MP-group interface.
Use undo ppp mp load-sharing mode strict-round-robin to restore the default.
An MP-group interface uses the smart load sharing mode.
For an MP-group interface in smart load sharing mode, the idle interfaces that have been recently used are used for sending packet fragments. For an MP-group interface in strict load sharing mode, interfaces are used in the order that they join the MP-group interface.
# Enable the strict loading sharing mode on MP-group 1/2/1.
[Sysname] interface mp-group2/0/0
[Sysname-MP-group1/2/1] ppp mp load-sharing mode strict-round-robin
ppp mp max-bind
Use ppp mp max-bind to set the maximum number of PPP links in an MP bundle on an interface.
Use undo ppp mp max-bind to restore the default.
ppp mp max-bind max-bind-num
The maximum number of PPP links in an MP bundle is 16 on an interface.
VT interface view
max-bind-num: Specifies the maximum number of PPP links in an MP bundle, in the range of 1 to 128.
IMPORTANT
IMPORTANT:
Use the default setting in most situations. Inappropriate use of this command can cause PPP performance degradation. Make sure you understand the impact of this command on your network before you use it.
Set the maximum number of PPP links in an MP bundle to be greater than the actual number of bound links. Otherwise, MP binding fails.
The maximum number of PPP links configured for an MP bundle takes effect immediately. If the configured maximum number is smaller than the number of existing PPP links, the existing links are not affected.
# Set the maximum number of PPP links in an MP bundle to 12 on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp max-bind 12
ppp mp min-bind
Use ppp mp min-bind to set the minimum number of PPP links in an MP bundle on a dialer interface.
Use undo ppp mp min-bind to restore the default.
ppp mp min-bind min-bind-num
On a dialer interface, the minimum number of PPP links in an MP bundle is 0, which means that MP dial-up relies on traffic detection.
min-bind-num: Specifies the minimum number of PPP links in an MP bundle, in the range of 0 to 128.
This command specifies the minimum number of PPP links in a MP bundle to ensure the minimum bandwidth for the service.
When the minimum number of PPP links is set to a non-zero value, subsequent MP dial-up operations will not depend on traffic detection, but existing dial-up connections will be removed upon timeout.
The min-bind-num argument cannot be greater than the maximum number set with the ppp mp max-bind command.
# Set the minimum number of PPP links in an MP bundle to 4 on Dialer 0.
[Sysname] interface dialer 0
[Sysname-Dialer0] ppp mp min-bind 4
ppp mp max-bind
ppp mp min-fragment
Use ppp mp min-fragment to set the minimum MP packet fragmentation size on an interface.
Use undo ppp mp min-fragment to restore the default.
ppp mp min-fragment size
The minimum MP packet fragmentation size is 128 bytes on an interface.
VT interface view
size: Specifies the minimum MP packet fragmentation size in the range of 128 to 1500 bytes. Outgoing MP packets less than the minimum value will not be fragmented, and those greater than or equal to the minimum value will be fragmented.
If MP binding is implemented through hardware (for example, CPOS chip), the minimum MP packet fragmentation size varies with chips. The minimum MP packet fragmentation size on certain chips can only be 128, 256, or 512 bytes. To successfully create the MP bundle and establish the sub-channel LCP link, make sure the setting configured with the ppp mp min-fragment command conforms to the hardware specifications.
# Set the minimum MP packet fragmentation size to 500 bytes on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp min-fragment 500
ppp mp mp-group
Use ppp mp mp-group to assign an interface to an MP group, and enable MP for the interface.
Use undo ppp mp to restore the default.
ppp mp mp-group mp-number
undo ppp mp
Interface view
This command should be used with the interface mp-group command. You can create an MP group interface and then assign an interface to the MP group. You can also assign an interface to an MP group and then create the MP group.
# Assign Serial 1/2/0/1:0 to MP-group 1/2/1.
[Sysname] interface serial 1/2/0/1:0
[Sysname-Serial1/2/0/1:0] ppp mp mp-group 1/2/1
interface mp-group
ppp mp short-sequence
Use ppp mp short-sequence to trigger MP short sequence number header format negotiation on an interface. After the negotiation succeeds, the local end receives packets with short sequence numbers.
Use undo ppp mp short-sequence to restore the default.
The long sequence number header format is used on an interface.
Interface view
This command applies to the incoming direction only. To enable the local end to transmit packets with short sequence numbers, execute this command on the remote end.
The sequence number format (long or short) of an MP bundle depends on the configuration of the first channel joining the MP bundle.
To negotiate the use of short sequence numbers on a common MP bundle, execute the command on all its channels. To negotiate the use of short sequence numbers on a dialer MP bundle, execute the command on the dialer interfaces and the ISDN D channels. The command will cause PPP re-negotiation.
# Configure the short sequence number header format of MP in the incoming direction of Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp mp short-sequence
# Configure the short sequence number header format of MP in the incoming direction of Virtual-Template 1.
[Sysname-Virtual-Template1] ppp mp short-sequence
ppp mp sort-buffer-size
Use ppp mp sort-buffer-size to set the MP sort buffer size factor on an interface.
Use undo ppp mp sort-buffer-size to restore the default.
ppp mp sort-buffer-size size
The MP sort buffer size factor is 1 on an interface.
size: Specifies the MP sort buffer size factor in the range of 1 to 64.
The MP sort buffer size = the number of channels in the current MP bundle × size. You can use the display ppp mp command to view the number of member channels in an MP bundle. If the calculated MP sort buffer size is 20, the MP sort buffer can sort 20 packets.
When MP is used, the received packets might be out of order. The sort buffer is used to re-sort packets. A large sort buffer results in better re-sorting but increases delay. For voice packets, the transmission delay should be minimized.
# Set the MP sort buffer size factor to 64 on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp sort-buffer-size 64
ppp mp timer lost-fragment
Use ppp mp timer lost-fragment to set the timer for MP to wait for the expected fragments on an interface.
Use undo ppp mp timer lost-fragment to restore the default.
ppp mp timer lost-fragment seconds
The timer for MP to wait for the expected fragments is 30 seconds on an interface.
VT interface view
seconds: Specifies the timer for MP to wait for the expected fragment, in the range of 1 to 255 seconds.
A receiving end puts the received fragments in the buffer and reassembles them when it receives all the packet's fragments. You can configure a timer for MP to wait for the expected fragments. When the receiving end receives the first fragment of a packet, it starts the timer. When the timer expires, the system checks whether or not all fragments have arrived. If they have all arrived, the system reassembles the fragments. If they have not all arrived, the system discards all received fragments to release the buffer space.
# Set the timer for MP to wait for the expected fragment to 20 seconds on MP-group 1/2/1.
[Sysname-MP-group1/2/1] ppp mp timer lost-fragment 20
ppp mp user
Use ppp mp user to associate a username with a VT interface.
Use undo ppp mp user to remove the association.
ppp mp user username bind virtual-template number
undo ppp mp user username
No username is associated with a VT interface.
username: Specifies a username, a case-sensitive string of 1 to 80 characters.
bind virtual-template number: Specifies a VT interface by its number in the range of 0 to 1023.
This command associates a username with a VT interface. After the user passes authentication, the system uses the settings on the VT interface to create an MP bundle and a VA interface to transmit data.
You can configure the following parameters for a VT interface:
·     Local IP address and the peer IP address (or address pool).
·     ppp mp-commands.
# Associate username user 1 with Virtual-Template 1, and set the IP address of the VT interface to 202.38.60.1/24.
[Sysname] ppp mp user user1 bind virtual-template 1
[Sysname-Virtual-Template1] ip address 202.38.60.1 255.255.255.0
ppp mp
ppp mp virtual-template
Use ppp mp virtual-template to bind an interface to a VT interface and enable MP for the interface.
ppp mp virtual-template number
undo ppp mp
Interface view
number: Specifies a VT interface by its number. The value range for this argument is 0 to 1023.
After you bind an interface to a VT interface, you can optionally enable PAP, CHAP, MS-CHAP, or MS-CHAP-V2 authentication.
The interfaces bound to the same VT interface are bound together. The ppp mp virtual-template command and the ppp mp command are mutually exclusive.
# Bind Serial 1/2/0/1:0 to Virtual-Template 1, and enable MP for Serial 1/2/0/1:0.
[Sysname-Serial1/2/0/1:0] ppp mp virtual-template 1
ppp mp
Use reset counters interface mp-group to clear statistics on MP-group interfaces.
reset counters interface [ mp-group [ interface-number ] ]
mp-group: Clears traffic statistics on MP-group interfaces.
interface-number: Specifies an existing MP-group interface by its number.
Before collecting traffic statistics regularly on an MP-group interface, clear the existing statistics.
If you do not specify the mp-group keyword, the command clears statistics on all interfaces.
If you specify the mp-group keyword without the interface-number argument, the command clears statistics on all MP-group interfaces.
If you specify both mp-group and interface-number, the command clears statistics on the specified MP-group interface.
# Clear the statistics of MP-group 1/2/1.
<Sysname> reset counters interface mp-group 1/2/1
shutdown
Use shutdown to shut down an MP-group interface.
Use undo shutdown to bring up an MP-group interface.
shutdown
An MP-group interface is up.
Executing this command to shut down an MP-group interface will make MP based on this interface become unavailable. As a best practice, make sure you fully understand the impact before executing this command.
# Shut down MP-group 1/2/1.
[Sysname-MP-group1/2/1] shutdown
